Keeper
Another thought is that the Jag is designed so that at ride height the half shafts are parallel to the ground. The inner and outer pivot points of the half shafts are closer together that those of the LCAs, so they swing in a shorter arc. So if you set up the camber so that it straight up and down at ride height, the tops of the tires are going to be pulled in as the wheels moves above and below ride height. I have a diagram somewhere on my computer that illustrates this. I'll have to look for it.
Now I know there are 2 schools of thought on this. One says the shafts are parallel, the other says the LCA are supposed to be parallel.
I have never been able to figure out which is the "correct" way.
With a full tank of gas, my LCA's are parallel. Though when I swap the springs out that may change.
