LM7 5.3
JeffK
Anyone out there seen a reasonable priced setup for alternator only on a LS engine? Best I found was 500$, nope. I saw a lower alt mount setup for @ 170 but doubt it will clear frame/steering box. Any LS guys out there?
i have used the ICT billet mounts. They run around $80. Clearance is tight but doable. On the lm7 you will need to drill and tap the block for the one bolt hole
Thanks! some good stuff on their site.
