Welcome to Our Community
Sign Up
Dismiss Notice
Master Cylinder ID
Discussion in 'Brakes' started by Track T-4, Jun 29, 2016.
  1. Track T-4
    Track T-4
    Expand Collapse
    Feb 27, 2008
    547
    10
    Gender:
    Male
    Occupation:
    Retired
    Can anyone ID this master cylinder? There are no part numbers visible on it.
    Thanks, Bruce
    Master cylinder front 2.jpg master cylinder left 2.jpg Master cylinder top 2.jpg
  2. RPM
    RPM
    Expand Collapse
    Administrator
    Staff Member Forum Sponsor
    Oct 16, 2007
    5,073
    657
    Just a best guess, Corvette. What is the bore in it
  3. Zandoz
    Zandoz
    Expand Collapse
    Apr 6, 2012
    1,142
    134
    Gender:
    Male
    Occupation:
    Retired eccentric
    I'd second RPM on it being a Corvette master. Unfortunately it will be difficult to determine the manufacturer due to the popularity of Corvette style clones.
  4. Track T-4
    Track T-4
    Expand Collapse
    Feb 27, 2008
    547
    10
    Gender:
    Male
    Occupation:
    Retired
    The bore is 1".
    Question: When should a 1" vs a 1-1/8" bore master cylinder be used? The car currently has power disc brakes front and rear.
    Thanks,.
    Bruce
  5. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    As you increase the bore size it takes less travel but more "foot" pressure to do the same job as the smaller bore , as I understand it . Are you having a brake problem ??
  6. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,329
    1,297
    Gender:
    Male
    Occupation:
    Retired
    With power assist I think the 1 1/8. would be the ticket. Have you asked Wilwood tech line?
  7. Track T-4
    Track T-4
    Expand Collapse
    Feb 27, 2008
    547
    10
    Gender:
    Male
    Occupation:
    Retired
    Yes. The brake pedal is to the floor with no effect from pumping. The car was around a few years before I purchased it, it then sat most of the past two years I've owned it while I got my track roadster on the road. Now trying to get it back on the road, have the upholstery redone, etc. The fluid in the MC was thick and brown so I decided to go through the whole system Replace rather than restore the MC etc. is a decision I'm trying to follow.
    Ron may be right with the Corvette ID since I've been told the calipers look like Corvette. I would like to stay with the same/similar replacement parts to avoid having to bend tubing, etc. Unfortunately there are no part numbers on anything.
  8. Larry
    Larry
    Expand Collapse
    Jun 10, 2015
    131
    29
    Gender:
    Male
    Is there a power booster? If so it mite be the check valve. If not pay no attention to me:D
  9. Track T-4
    Track T-4
    Expand Collapse
    Feb 27, 2008
    547
    10
    Gender:
    Male
    Occupation:
    Retired
    Yes there is a power booster. Everything is already disassembled right now so I'll check the valve when everything isdput back together.
Share This Page
SSL Certificate
