swatman260
I currently have a FAST EZ-EFI system on by bucket that I am having problems with. I purchased the efi to make my car more reliable, and I'm having the opposite experience. After spending way too many hours on the phone with their tech support, I have decided that I may pull the system and go with a carb. So, my question is this...I have built the whole vehicle to opperate off this EFI. I built the fuel cell with an in tank fuel pump with a return system. The FAST fuel regulator regulates the fuel pressure as it EXITS the carb, on the return line. Would I be able to re-plumb this regulator and have it control the fuel going into the carb, and just eliminate the return line? I realize I would have to rewire the power to the fuel pump, but keeping the existing regulator would be the simplest solution, because it's mounted to my firewall, and I don't want holes there if I remove it.
