Welcome to Our Community
Sign Up
Dismiss Notice
My ProjecTee
Discussion in 'Project Plans & Updates' started by DonnyRay, Aug 20, 2018.
  1. CheapT
    CheapT
    Expand Collapse
    Apr 28, 2022
    250
    135
    Gender:
    Male
    Occupation:
    Fundraiser - Please Donate to Keep This Site Going
    Okay. Well, I did take some measurements for you. Overall length of rack is 42", rack mounting points are 12" on center, rack body width 22" My frame width is 25"
    TheYeti likes this.
  2. CheapT
    CheapT
    Expand Collapse
    Apr 28, 2022
    250
    135
    Gender:
    Male
    Occupation:
    I think the heim joints would work out much better that tie rod ends and be easier to to work with. I'm going to research what I can use for my project
  3. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,805
    1,319
    Gender:
    Male
    Occupation:
    retired.
    Hi indycars ; I have 2 of those tools. Locating them is another story. However ; I have NO problem locating Lowes. I grab some snacks & visit with the employes. I enjoy going to Lowes. So , there's NO problem here. I go to a restaurant every morning & i eat my breakfast. I scout around for parts , i run errands for Leroy ( the shop owner). All of these trips i make , help break up my otherwise boring existence.
    Spanky, Indycars and lincolnuT like this.
  4. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,805
    1,319
    Gender:
    Male
    Occupation:
    retired.
    FIAT 500 r&p steering assembly..jpg This Fiat 500 R&P looks very simple & easy to install. It mounts behind the axle. It is manual (non power assisted).
    #1624 DonnyRay, Dec 25, 2022
  5. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,805
    1,319
    Gender:
    Male
    Occupation:
    retired.
    More information: 35 R&P DIAGRAM..jpg
    Spanky likes this.
  6. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,805
    1,319
    Gender:
    Male
    Occupation:
    retired.
    The length of the steering gear housing is extremely important. I have a great fitment with the Chevy Cobalt's steering assembly. I'm going to see if my Honda Del Sol's R&P inner tie rods will fit my Chevy R&P's steering gear housing. The Chevy Cobalt's inner tie rods are too long. The Honda Del Sol's inner tie rods are shorter. I may have to use the Honda's gaiters also. I'll have to purchase a banding tool when i put everything back together.
  7. Spanky
    Expand Collapse
    Jul 29, 2016
    3,023
    2,428
    Gender:
    Male
    Have you driven a T-bucket with a steering rack like the one you are planning to use? I wonder if the handling is really worth all the effort . . . o_O
    rbsWELDER likes this.
  8. PotvinGuy
    PotvinGuy
    Expand Collapse
    Staff Member
    Feb 22, 2008
    1,852
    770
    Gender:
    Male
    Occupation:
    My first T had conventional box/drag link steering. My current T has R&P. The only big difference was steering effort; R&P is like power steering compared to conventional steering. R&P is very light and easy. But R&P has a downside: the connection between the road wheels and the steering wheel works both ways equally. So every bump in the road is transmitted right to the steering wheel. Hard on the wrists. And the control of the box is gone, so the road wheels move freely with every bump, which can be scary. The solution is one or more steering dampers. I use a pair of motorcycle dampers: IMG_0036.JPG
    ...the black cylinder. Mounts to the batwing. One on each wheel. There are many other dampers, like this one sold by speedway.
  9. PotvinGuy
    PotvinGuy
    Expand Collapse
    Staff Member
    Feb 22, 2008
    1,852
    770
    Gender:
    Male
    Occupation:
    You will want to check the stroke on any damper to see how far you can turn the wheel in both directions. Most automotive dampers are sold for a particular vehicle and the description won't have stroke or body length, so you have to ask. And then decide where to mount the damper considering the stroke and other parts in the way. This is why we get the big bucks, right?
    Here is the latest damper I bought. It has a 5" stroke, which will give you 2.5" in each direction. It came with the mounting bracket even tho the listing said it didn't. I haven't installed it yet, but it will give me more wheel turning than the present damper which has only 2" in each direction.
    #1629 PotvinGuy, Dec 27, 2022
  10. lincolnuT
    lincolnuT
    Expand Collapse
    Mar 21, 2008
    1,825
    474
    Gender:
    Male
    Occupation:
    Retired
    My Half Rack is so much better than the old Corvair boxes. It turns easier sitting still and going down the highway. I alos don't seem to get the same wheel feel that Potvinguy speaks about..............
  11. PotvinGuy
    PotvinGuy
    Expand Collapse
    Staff Member
    Feb 22, 2008
    1,852
    770
    Gender:
    Male
    Occupation:
    What's a half rack? Got a pic? Oh, the Unisteer! Very interesting. Does the steering column bolt directly to the unit? Plenty of turning at the wheels? Does the unit move a drag link or a cross link or how does it all go together?
    #1631 PotvinGuy, Dec 27, 2022
    lincolnuT likes this.
  12. LongJohn
    LongJohn
    Expand Collapse
    May 10, 2022
    51
    32
    Gender:
    Male
    I have a Unisteer unit. I haven’t driven it yet but I think it’s 3 1/2 turns lock to lock and designed fir 6” steering arms. My wheels turn about 38 degrees each way if I remember right. It’s the same as Ricks bucket. With the bell crank I can change the ratio fi I need to.
  13. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,791
    554
    Gender:
    Male
    Occupation:
    Retired
    I have the 28 - 32 cross steer model. It is 3 3/4 turns lock to lock, 6" total drag link travel.
  14. lincolnuT
    lincolnuT
    Expand Collapse
    Mar 21, 2008
    1,825
    474
    Gender:
    Male
    Occupation:
    Retired
    Yes about 3.5 turns lock and steers very smooth.......It hooks right up to the steering shaft these photos should make that clear. I hooks to the same place as the drag link.........
    PotvinGuy and Spanky like this.
  15. rbsWELDER
    rbsWELDER
    Expand Collapse
    Dec 1, 2008
    822
    214
    Gender:
    Male
    I agree with all of the above comments! Changing from the Corvair box to R&P was amazing! It was like I installed power steering!!!
  16. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,805
    1,319
    Gender:
    Male
    Occupation:
    retired.
    My inner tie rods are too long. Took my Chevy Cobalt R&P assembly to Geiger Manufactures (machine shop) to have them shortened. I'll check back with them 1-6-23.
  17. AltBantam
    AltBantam
    Expand Collapse
    Aug 12, 2022
    62
    51
    Gender:
    Male
    LincolnuT, are you running that unisteer as a side steer? If so, can you post a few more photos from the front end, etc... Sorry, I did not mean to highjack the Thread but this is an option I have not considered...
  18. lincolnuT
    lincolnuT
    Expand Collapse
    Mar 21, 2008
    1,825
    474
    Gender:
    Male
    Occupation:
    Retired
    Yes it is a side mount. I can take some diffrent angles if you want/need but it just goes down and hooks up just like the drag link does to the steering side of the front end.....Try it you will like it............
    Spanky and AltBantam like this.
  19. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,805
    1,319
    Gender:
    Male
    Occupation:
    retired.
    Here's an update on the shortening of my inner tie rods : DSCN1548.JPG The lower tie rod on the top has been separated to show it's inner core. The inner core & the left side of the lower tie rod are machine cut from one solid piece. The threaded side of the top lower tie rod was drilled through it's center. The 2 lower tie rod halves are pressed together. The lower tie rod will then be welded. I am very impressed with Geiger Manufacture's work. I'll be using them again in the future. I removed the 2 steering rods & welded the 5/8" holes solid. I smoothed out the welded areas with a 40 grit flappy disc. Then i re-drilled the steering arms with a 9/16" drill bit (14mm). In other words , the original holes were 1/8" too big to fit my heim joints. I'm supposed to pick up my R&P assembly on Tuesday 1-10-23.
  20. AltBantam
    AltBantam
    Expand Collapse
    Aug 12, 2022
    62
    51
    Gender:
    Male
    Thanks. Will you post a photo of the front where the unisteer mounts to the spindle?
Share This Page
SSL Certificate
