Welcome to Our Community
Sign Up
Dismiss Notice
My ProjecTee
Discussion in 'Project Plans & Updates' started by DonnyRay, Aug 20, 2018.
  1. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    Spanky , 10 years time is undeniable proof that you have patience. Also a very strong will.
  2. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    Still working on my roof hinge. Will take some photos when i finish.Weather should be clear Thursday 3/23/23.
    rbsWELDER likes this.
  3. LongJohn
    LongJohn
    Expand Collapse
    May 10, 2022
    64
    40
    Gender:
    Male
    I have seen real heavy duty hinges at the welding supply store. Bronz lubuable bushings if you think heavy duty long life stuff.
    rbsWELDER and Spanky like this.
  4. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    Sounds good ORF. If the hinge i'm using doesn't work out ; i'll make a bee line to my nearest welding supply store.
  5. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    My roof hinge is functioning pretty good. I'll take some photos after the next rainstorms pass. Looks like Thursday and Friday (3-30-23 & 3-31-23).
  6. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    Photos of my roof hinge : DSCN1578.JPG DSCN1579.JPG As i was lifting the roof i noticed a little body flex. I will address that problem. I will install some fiberglass bracing. Maybe an X shaped brace.
    #1666 DonnyRay, Mar 29, 2023
  7. LongJohn
    LongJohn
    Expand Collapse
    May 10, 2022
    64
    40
    Gender:
    Male
    I like it!
  8. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    Thank you for your compliment LongJohn.
  9. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    Just my two cents worth : I value the opinions of my fellow car builders ( whether good or bad) they have hands on experience, We are all participants in the same genre. I ignore the comments & criticisms of non - builders. A non-builder has nothing but individual likes & dislikes to base his or her criticism or compliments on. JMTCW.
  10. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    Still working on my roof hinge I'm trying to eliminate excessive body flex. I'm making an x shaped brace. I'm using 1" x 3" pine to make a form I will glass over the form then separate the finished fiberglass from the form. I'll glass the finished fiberglass x shaped piece to the inside of the body. The x shaped piece will be glassed between the verticals of the lower hinge.
    #1670 DonnyRay, Mar 31, 2023
  11. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    My "X" shaped brace : DSCN1588.JPG DSCN1590.JPG Will be installed higher than it is in the photo.
    James Louis likes this.
  12. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    The hinge pins allignments were in a bind. That was corrected. Now i have less body flex. I'm still going to install the "X" brace. Because it's already made. LOL !! The "X" brace was made before i discovered the binding hinge pins. OOPS !!
  13. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    I'm replacing the roof hinge with another hinge (1925 model t touring door hinge). DSCN1591.JPG DSCN1592.JPG
  14. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    Here's a photo of the 1925 model t touring door hinge : s-l1600.jpg
    lincolnuT and Spanky like this.
  15. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    Some more progress photos: DSCN1593.JPG DSCN1594.JPG DSCN1595.JPG DSCN1596.JPG I did some more trimming on my "X" brace then i attached it inside the rear of the body , between the lower hinge pads.
    #1675 DonnyRay, Apr 20, 2023
    choppedtop, James Louis and rbsWELDER like this.
  16. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    Started working on my new roof hinges today (4-20-23). I took my 2 steps to Geiger Machine shop to have then modified. I want them to fit closer to the body. Supposed to pick them up on 5-5-23 @ noon. I have my project up on 4 ramps right now. I have some welding & cutting to do. I need to change my th350 to the 700R4 (which i purchased rebuilt a few months ago). I also have a 2100 stall speed converter for the 700R4. I need to add 2 more pieces to the rack n pinion steering system. I also need to remove ( with a plasma cutter) the current Vega steering box mount.
    Spanky likes this.
  17. Spanky
    Expand Collapse
    Jul 29, 2016
    3,240
    2,763
    Gender:
    Male
    I saved this pic to remind us what the whole car looks like . . . :rolleyes:
  18. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    I had forgotten all about this photo. I downloaded it & saved it to my "projecT" folder. Thanks for the photo Spanky.
  19. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    More photos of roof hinge installation & an added feature : DSCN1598.JPG DSCN1600.JPG DSCN1601.JPG DSCN1602.JPG DSCN1603.JPG
    James Louis and choppedtop like this.
  20. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,872
    1,372
    Gender:
    Male
    Occupation:
    retired.
    Thanks for your likes guys.
Share This Page
SSL Certificate
