Need some master cylinder help
0rg0
I'm using stock pedals in my car, and I could use a stock master but...
I've had the experience of full brake failure before, and I want to use a dual master. Drums all around. Anybody know what's going to be a best fit for this application ?
'67 Mustang drum / drum if it will work with your pedals.
I've used those before, but the problem is the outlets for the lines would end up on the wrong side.
What kind of pedals are you using?
