Hello out there! Name is Rande, I live in southeastern Minnesota (Winona). I am not building a Tbucket but I am using a Tbucket style frame. I hope you don't mind my asking a few qustions here.I have read many threads about caster via the search function. Have learned much. Thanks to all the guys that are willing to share and educate. but, even with the searches and reading, i find I need some advice.
I am using a suicide style front with spring over axle, perch under spring. Long harpins (Speedway "Curtis"). During the frame build, my brother got a little ahead himself and fully welded the, then, tacked on perch. We hadn't yet gotten the front caster set. Measured it today with a simple angle gauge. The round ones with the hanging pointer.
Measured at the top of the kingpin and the top plate at the perch. Same 2* at each location so the spring is inline with the kingpins.
So, I have 2* of caster. Not enough from my reading here. I undestand that I can set the caster by adjusting the clevis's on the batwings or lowering the rear of the hairpins or, I would guess, a combination of the two.
The info that I am concerened about and have not found during my search is: How far can I adjust the caster via the clevis and/or hairpin methods before I begin to twist the spring and deflect the rubber bushings in the springs too much? From my reading, I am aiming at 7*. That's a 5* change. This seems a bit much. My reading suggests these adjustments should be used for fine tuning and the perch should be the main dictator of caster. I'm thinking a 5* change is beyond fine adjustment.
The frame is, as yet, unpainted. I am thinking its best to cut the perch off and reweld at 7*. The frame is presently sitting on the axles and tires at near its ride height and angle. It will settle some when the steel truck cab and wood flatbed are mounted. I will approximate that weight tomorrow when I go back to the shop (60miles away) before we do anything.
Now, for more general info, here is a link to the HAMB where I have an old thread with pics of what I am building. http://www.jalopyjournal.com/forum/showthread.php?t=325728&highlight=strep
It presently looks like a ratrod but that is not what its going to be. It will be painted (with shiny paint!) and dressed up a bit. If it comes out looking ugly, that will be inadvertant, not a design goal. If you look it over, I'd apreciate any feedback as to any concerns about the frame and suspension construction.
I have read that it would be preferable to have the drag link and tie rod mounted above the steering arms, I'm going to look into that tomorrow.
Any help you can offer would be greatly apprciated. This is my first hotrod build.
