Oasis Floral Foam.....Where can I find a good deal?
The other plus is w/only 1 thickness of glass , it will be much simpler to mount your gauges !!
Have to cut steel support beam to make gauges fit any way. Grey circles and rectangles are area the needs removed to install gauges.
I ran the angle across the top of the dash, inside, above where the gauges mount. I cut pieces of flat stock to fit in the corners above the door posts, where the windshield posts bolt to the body, and welded the door posts, and the cross brace to them. Now the dash, door posts, windshield posts are all tied together and strong. I then cut a flat piece to fit against the inside of the firewall at the top and the bolts that hold the stainless firewall plate holds it in place. It will be glassed in later as well, I also routed the inside of the firewall for that plate to recess and be totally flush, so when I glass over it, it will be invisible, flat, strong, and thin. There are some flat pieces that connect the dash cross brace to the cowl plate up tight against the inside of the cowl forming a cage, sort of. I also welded some flat stock that drops down from the angle cross brace (dash cross brace) against the inside of the back of the dash with a plate between it and the firewall plate for the column drop to connect. The bottom of the door posts are also welded to plates that are routed into the floor and bolt to the frame. It's all very strong, allows rigid mounting of everything, and out of the way of dash components. I will also encase everything in glass moving forwards to eliminate any possible rattling and to make everything stronger. Perhaps you could modify your setup with that in mind if it will help.
I like your dash, clean, symmetrical, not cluttered. Nice! That is similar to what I have in mind for my project. What did you use for the plate? I salvaged a nice large piece of brushed stainless steel from a side by side refrigerator door that I have been contemplating incorporating on my dash. I am not committed yet. I really like the look of the auto meter American Classic series with the stainless face plates, but I'm still choking on the price... When I bought the bucket, it came with a old dash plate gauge bezel that is shaped like a '32 dash center section, it's Ss with a brass plate in the center. I like it, and it's different than most I see, but it only has provisions for one large and four smaller gauges, so I'm on the fence because I want a dash mounted tach that matches, and the symmetric thing...
The face of my dash was made from some engine turned sheet stock that I bought from Speedway.
Just a small picture update of the recent layer of fiberglass.
Before Pic
Glass cut
After Fiberglass Pic
This last pic I still need to sand all the edges and the open holes for the tail lights. I will sand and clean those areas out and then re-glass them separately. I am hoping to get that done this weekend a long with laying a layer of glass on my dash.
Perhaps this picture may give you some ideas. The bottom of my dash is a piece of 3/4"x3/4" square tubing. It is supported by the same tubing on either end that goes clear to the floor and connects to a piece of 3/16" plate that extends inward and stops over the frame creating a strong body mounting point to the frame. The tubing in the bottom of the dash mounts the homemade column drop and it is completely wrapped in glass creating a feature that compliments the feature that wraps over the top of the dash.
This is the first I recall noticing your dash. I'm planning on centered speedo & tach like you have, but I'm up in the air on the auxiliary gauge placement. I had originally planned on a simple under dash 3 gauge panel...but that's not going to work. My 2nd choice right now is to put the 3 to the right of the speedo & tach, but I'm concerned about the readability. My dash is at least 4" farther away than usual because of the stretch. What diameter are your gauges, and how is the readability of the right gauges?
Bill, the OD of trim rings on my gauges is 3 1/2" and 2 1/4" respectively and the space between each gauge trim ring is 3/4". The layout of the gauges from left to right is Temp, Oil, MPH, RPM, Fuel & Volts. As for readability, I've had no problem. But that has a lot to do with the position of the seat, the steering column and the steering wheel. I'm a great believer in ergonomics. Without taking that into consideration you'll have a very uncomfortable driving experience.
When building my car I spent a lot of time experimenting with seating positions and steering column angles etc. to make an enjoyable driving ride. My wife and I both have RA so comfort is VERY important. We can cruise for several hours and many miles with absolutely no discomfort.
I'm thinking MPH & RPM centered, with temp, oil, & volts on the right. That's going to put the volts clear to the right end of the dash, and the one I'm worried the most about readability. I'm planning on the shifter to the left of the MPH & RPM. The ignition and light switches will go in a pod on top of the steering column, or clear to the left end of the dash. The dash treatment is going to be simple...just aircraft style rings on each gauge.
With nothing near the steering column, I'll have a lot of wiggle room to get the column comfortable. Seating is still a HUGE issue, that would be too much more of a hijack than this already is, so I'll tackle that issue elsewhere soon.
Maybe I should start a new thread on this, but we will see what people have to say. I am still working on my truck bed and getting some things cleaned up on it. I sanded the latest layer of glass this weekend. It's all I had time for on the bucket last weekend. Basically I am looking for opinions on what to do here. When it is all said and done I would like my box cover to be nice and level. Right now it is out of level quite a bit. To fix this I will need to be really creative on how I build up the low spots on the body, and we are not talking about a couple millimeters here that can be fixed with filler alone.
The front sides of my box by the cab are less severe at about a 3 degree incline. The rear of the box by the actual Tail lights is the most severe at 9 degrees of an incline.
So should I get creative and use cloth and resin to gradually build up the areas to meet the 9 degrees, or just create a setup that allows my truck box cover to mount higher towards the cab and rest on the rear?
Front of box.
Rear of box.
If I make the sides all 0 degrees I will also need to take the center of the box up (Tailgate)
Which can some what be seen in the opposite corner of the sander as seen in this photo. So gentlemen can you just give me some recommendations on how you might approach this?
Thanks
Did adding the glass pull the flanges up?
Here's what I would do.
Slice the recent glass work behind he steel frame and open the cut up until the areas are level again.
Put wedges in the gap to hold the flanges level. Find a way to hold the flanges in place. Remove the wedges and V out the gaps 3/8" to 1/2" wide just like prepping for welding. Mask off the sides of the V and pack the V with a mix of resin and chopped glass.
I was thinking of adding small strips of Matte to build up in areas and then use filler to smooth out the transition between the two.
Also what deck hinges did you use on your lid?
BMW E46 99-05.
I used aftermarket 12" gas props cause the OEM 13" made the lid open past 90°, like the newer cars do. Looked goofy on my car.
You could surely do that too.
Jim, how did you do the the raised portion of your dash? I was thinking of sculpting it with body filler.
Thanks Bill
Thanks Bill
Yes, most of it was sculpt with filler that has fiber glass strands in it. We made a template out of a piece of aluminum and used that to shape the filler.
First Layer Drivers Side, Red line is where I will sand/cut to.
First Layer Passenger Side
It has dried and I have put an additional layer on the drivers side already. I need to put another on the passenger side and then 1 more complete layer. Then I will cut down to correct size. Sand the top of the bed and add enough layers as needed to make the side even. I will then flip the bed upside down and sand and add filler to the bottoms to make it curve with the contour of the body.
This is so much easier then applying 5 or 6 layers just to build up the side of the the bed to match the corners.
Looking good.
Re the instruments. I am toying with the idea of mounting the temp and fuel gauge somewhere out of sight and using a hidden mirror to see them.
Could be in the seat riser, could be under the dash, could be between your legs, anywhere. I also thought of using the laser pointers of various colors mounted under the seat and shining their point light up on the dash instead of idiot lights.
Course I do come up with some silly stuff.
G
