I'm trying to decide which engine I want. I'd LIKE a BMW V10 or Ford V10 or something similar but that isn't going to happen. After doing a lot of research I've decided to go with a NEW Chevy block and build it up with all new parts. Not aiming for earth shattering power, around 400hp should be good.
I can get a "reconditioned" 350 SBC bare block for $790. This is a 1996 - 2000, 4 bolt main, clearanced for 3.73 stroke with I bean rods, and is 0.030 over. Ready to build, no machining needed.
This would end up either 355 or 383ci. The "Rotating assembly" (Crank,rods, pistons) I'm looking at are rated for up to 500hp.
Parts for this block are plentiful and as far as I can see... relatively cheap.
OR
an IRON LS gen 3 323ci (5.3L) bare block .... NEW... for $350.
IF I go LS I may keep the fuel injection but that adds $$$
OR I could go with a carburetor.
The LS is heavier, smaller capacity.
Remembering these are both bare blocks with NO internals and will need EVERYTHING....
What would you use?
Thanks.
OR
What would you use?
Thanks.
