anyone see any reason one can't set the pinion close before tacking it in? The reason I ask is my shock brackets on the frame follow the rake at about 5 degrees and I would like to keep the shock mounts near the same or 1 degree less on the rear end housing so that if I need a little more pinion I can get it without turning the shock/ 4 link brackets out of shape. I know they should be 90 degrees to the floor but they were on the frame when I got it and I would like to use them. They are stainless bolted on with six bolts. I moved them back and can use two of the original bolt holes and everything is square and in order with the engine and trans mocked I have 1.5 to 2 degrees in the pinion with 1/2 inch between parallel center lines of trasnmission and pinion and a 15 inch center to center of the u-joint drive shaft. If it sounds good to you all it"s. ready to tack up. I should add it's all set at 12.5 inch ride height.
Thanks jeff
Thanks jeff
