Pontiac Front wheel cylinder line adapter
23 T 4sp
Here is my problem. I was told the brakes are off a 1961 pontiac catalina.
The rubber hoses are shot and were to short anyway. So i ordered adapters
To go from the wheel cylinder to a -4 an. All the steel lines are 1/4". The
Adapter end threads into the wheel cylinder is shorter than the threads on the
Original rubber hoses. The hoses have an inverted flare. Looking into the
Wheel cylinder threads i do not see a flare to match which seems impossible.
Anyway does anyone know where to buy an adapter for pontiac wheel
Cylinders that has the same thread depth as the original hoses ?
Thanks for the reply with pictures it really helps me out.
Never thought about using a banjo.
Wish I could post pictures to show my problem.
Too make it work I had to swap sides with the wheel cylinders. If I didn't then the line would have
been directed right back into the backing plate. Just the opposite of what you see in the photos.
