fletcherson
I’m assuming you are referring to a adjustable proportioning valve. Typically you have more fluid directed to the front brakes by master cylinder design, so it would seem to be logical to be able to adjust that variable to obtain balance on light cars. I chose to install it that way on mine for that reason plus having narrow front tires. I didn’t want the fronts turning into skis. I’m sure there are numerous other variables that could figure in depending on your particular situation like master cylinder selection, brake type, caliper or wheel cylinder size, car weight, you get the idea.
![brake lines (3) [640x480] (2015_11_13 11_07_31 UTC).JPG brake lines (3) [640x480] (2015_11_13 11_07_31 UTC).JPG](https://tbucketeer.com/data/attachments/17/17553-782cfecff2654d31d14ac47eef173c28.jpg?hash=eCz-z_JlTT)
