Welcome to Our Community
Sign Up
Dismiss Notice
Project Blue Bird
Discussion in 'Project Plans & Updates' started by TrueBlue, Jun 17, 2020.
  1. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,569
    845
    Gender:
    Male
    Occupation:
    Retired
    Thats the first thing out of their mouths. “Make and model.”
    TrueBlue likes this.
  2. TrueBlue
    TrueBlue
    Expand Collapse
    Jun 10, 2020
    119
    185
    Gender:
    Male
    Wow..and relatively cheap too. I need to figure out what ends I need I guess. So AN3 fitting in the frame side, and what about the caliper side? I know what it looks like..just not sure the proper wording for it ‍♂️
  3. TrueBlue
    TrueBlue
    Expand Collapse
    Jun 10, 2020
    119
    185
    Gender:
    Male
    I hate it.
    There are 2 girls that work at 2 of our local shops..Napa, and a KOI. Both are 10 times as knowledgeable as the dudes that work there. Not many old timers around anymore. My dad always tells me stories of a local shop in the 60’s to 80’s called Toohey’s..(so appropriate a name for that kind of shop too I must say) said all you had to do was tell them what you needed and they knew exactly what you wanted. Good ol days perhaps
    lincolnuT and Spanky like this.
  4. Spanky
    Expand Collapse
    Jul 29, 2016
    3,300
    2,850
    Gender:
    Male
    I guess the moral of this story is, we need to keep working to pass our hot rod passion to the younger generation(s). That's why I feel obligated to go cruising in mine around the local area as much as possible. Youngsters still dig it!
  5. MMC757
    MMC757
    Expand Collapse
    Apr 28, 2021
    106
    53
    Gender:
    Male
    Occupation:
    I get paid for what I know
    The last time I needed brake tubing they didn't even ask me any questions, just brought me to the back where all the brake lines were at and left me alone to figure it out.
    TrueBlue and lincolnuT like this.
  6. rubicon
    rubicon
    Expand Collapse
    May 28, 2007
    863
    258
    Gender:
    Male
    In Racine during the 60's and 70's there were quite a few places that worked on engines and trans. Reworking the heads, bores, cranks and whatever you needed done. All parts stores had knowledgeable guys that knew what you needed and if they didn't have it could tell you where to get it. Now if it isn't in the computer they have no idea where to look or what will work. Sad.
  7. TrueBlue
    TrueBlue
    Expand Collapse
    Jun 10, 2020
    119
    185
    Gender:
    Male
    The excitement is building
  8. TrueBlue
    TrueBlue
    Expand Collapse
    Jun 10, 2020
    119
    185
    Gender:
    Male
    Hey folks…we’re still plugging away. But now that I’m to the fuel lines, I need some advice. I’m thinking from the tank, a steel braided hose over to the frame rail. Then aluminum line to the front, to a short braided line to the fuel pump. I’m not quite sure what fittings to start with in the back, and how to connect to the steel braided to the hard line at the frame. Can someone show me some examples or links if possible? So I can make sure I’m on the right track.
  9. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,372
    1,346
    Gender:
    Male
    Occupation:
    Retired
    I would use steel line for gas. Methanol messes with aluminum. There are adapters from A/N fittings to flare fittings.
  10. PotvinGuy
    PotvinGuy
    Expand Collapse
    Staff Member
    Feb 22, 2008
    1,902
    833
    Gender:
    Male
    Occupation:
    I use black braided line and AN fittings for the whole system. 10AN from tank to first filter (100 micron), then 8AN from filter to electric pump, then 6AN from pump to second filter (10 micron) and 6AN from there to injector rails. This is for EFI, carbs probably don't need two filters. I like to minimize transitions, so don't use any hard lines.
    I just stumbled onto your project, so I will read it from the start and then mercilessly kibitz.
    #170 PotvinGuy, Oct 4, 2021
  11. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Here's some hard line to AN fittings.
    https://www.summitracing.com/search...rder=Ascending&keyword=hardline to AN fitting
  12. cfciii03
    cfciii03
    Expand Collapse
    Sep 29, 2021
    27
    9
    Gender:
    Male
    Very helpful - thanks.
  13. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,604
    1,200
    Gender:
    Male
    Occupation:
    Information Technology (IT) 15yrs, Then Retired
    This is what I did, except I didn't have room for the first filter. The filter between the shut off valve and fuel pump.
    Below is what it looks like when you are making a flexible line.
    You will need a flaring tool that does 37° flares if you are using AN fittings. If are going with SS lines in some sections, then it will need to be a good flaring tool.
    TrueBlue, PotvinGuy and Spanky like this.
  14. TrueBlue
    TrueBlue
    Expand Collapse
    Jun 10, 2020
    119
    185
    Gender:
    Male
    thank you all!!!!
  15. Wyo George
    Wyo George
    Expand Collapse
    Dec 17, 2014
    54
    18
    Gender:
    Male
    I’m loving the blue and I’m a fan of the big Caddy engines so this build is fantastic in my opinion. Keep up the good work.
  16. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,888
    1,384
    Gender:
    Male
    Occupation:
    retired.
    My current project is actually my second t bucket. My first t bucket was started & abandoned a few weeks later. The first t bucket had a Cadillac 429 c.i.d engine. The donor car was a 1966 Calais. That attempt happened several decades ago ( had less tools & less knowledge then ).
    rbsWELDER and lincolnuT like this.
  17. TrueBlue
    TrueBlue
    Expand Collapse
    Jun 10, 2020
    119
    185
    Gender:
    Male
    We got some paint on it this weekend. Hope to marry it to the frame soon.
  18. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,888
    1,384
    Gender:
    Male
    Occupation:
    retired.
    WOW !! Thanks for the great pictures TrueBlue.
  19. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,569
    845
    Gender:
    Male
    Occupation:
    Retired
    It’s definitely BLUE! I like it. Nice job.
  20. Island Girl
    Island Girl
    Expand Collapse
    Jul 21, 2018
    1,072
    1,139
    Gender:
    Female
    Occupation:
    Manager
    That's looking GOOD!
Share This Page
SSL Certificate
