Bugflipper
Okay fellows I have a cam recomendation thread going and that has me wondering about stall speed. I do not want to rev up to a given rpm and launch a car. Just a normal take off, letting off the brake and stabbing the throttle if so inclined. I understand a higher stall can prevent the car from being so hard to hold at a stoplight. Are those the only two uses of a higher stall converter? I have disc brakes on both buckets and wider front tires than normal to aid in making the discs useful. Holding the cars back at a stop isn't a chore. Just takes more effort than power brakes would. Is there something else I'm missing here on the benefits of a smaller toque converter? I don't intend to go to the dragstrip so I don't see the need. Also with big drag radials it looks like those little 10 bolt rears that are so popular would be stressed to their max with a 3000 rpm launch.
Thanks.
Thanks.
