Zack
I know this has been covered many times but i am still wandering if i should use them or not. I have heard conflicting stories about using them vs. not using them. Can some of you shed some light on this for me again? I have 4 wheel disc brakes on my Bucket. My pedal/MC will be mounted on the inside frame rail slightly above the front brake calipers elevation and slightly lower than the rear calipers elevation. I don't want to use them if i don't have to because once i run my hard line tubing with them installed and i take them out later, then i have a botched up brake line. This is what i am hoping to avoid.
Thanks
Thanks
