Okay, I think I MAY have a possible solution for my steering column. The shaft I use now, is a tube 3/4" in outside diameter and 5/8" inside diameter. I have a Grade 8 bolt and nyloc nut attaching it to the short shaft coming out of my iron Corvair box. The steering wheel is attached to the Grant steering wheel hub piece, which is held to the shaft by a grade 8 bolt. The bolt goes through the hub, then into the tube and a nyloc nut is attached. It works, but there is a slight movement due to column tube and inner bushing. Tatal P has the column in 3 lengths. I'm going to get the longer so I'll be able to cut off what i need for fit. Now, the only problem I see is a cosmetic one. The hub will be visable. I propose cutting a piece of PVC that will tightly slip over it, then attaching the wheel to the hub with the 3 bolts supplyed.
Does this sound like it could work? The shaft I am using works fine. I figure why use a coupler, when the whole shaft could serve the same purpose. The coupler/tube would seem to me to be weaker compared to a shaft that is one piece and attached to the steering box shaft.
Please, read and let me know if this is feasable and SAFE. While I hate to skimp on cost when it comes to safety stuff, the Total P column tube comes welded to a 3/16" plate that attaches it to not only the floor, but the frame. The cost is $40. Their nylon bushing, which has a 3/4" hole for a shaft (the same diameter as my tube) is $6. The two, plus shipping and a little hunk of PVC tubing could get me done for about $50.
So, let me have your thoughts. If what I have isn't as sake as a solid shaft with a coupling, I'll probably just drop the bucks for the Speedway unit & U-joint, and be done with it.
