Welcome to Our Community
Sign Up
Dismiss Notice
So does this sound right?
Discussion in 'Brakes' started by ChrisK, Jul 26, 2015.
  1. ChrisK
    ChrisK
    Expand Collapse
    Feb 7, 2015
    141
    32
    Gender:
    Male
    Im getting parts together for my brake system. So far I have tandem master cylinder with 7" booster. A universal combination valve, 2 lb residual for the front discs and a ten pound one for the rear drums. All Chevrolet parts. The master is going under the driver seat on the frame with a pushrod to the pedal. That's the plan so far. Any thoughts? I also have a adjustable proportion valve for the rear. Don't know if I will need it.
  2. EX JUNK
    EX JUNK
    Expand Collapse
    Moderator
    Feb 5, 2008
    2,997
    517
    Gender:
    Male
    Occupation:
    Retired electrician
    I personally see no need for a booster. With these cars, as light as they are, it take very little foot pressure to bring them to a control stop, even from speed. IMHO
  3. RPM
    RPM
    Expand Collapse
    Administrator
    Staff Member Forum Sponsor
    Oct 16, 2007
    5,073
    657
    Yep no booster needed. Most of the brakes are from a 3500 lb car and now we have them on a 1600 lb car. Plenty of stopping power.
  4. ChrisK
    ChrisK
    Expand Collapse
    Feb 7, 2015
    141
    32
    Gender:
    Male
    I got a 1200 stall converter on this trans I got that why I went with the booster. I haven't put anything on the car yet I will probably go without the booster now.
    cooter likes this.
  5. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    there are many different size[bore] chev MC's as well as different bore calipers & wheel cyl,'s... You have to figure out if what you have will play together nicely..
  6. PotvinGuy
    PotvinGuy
    Expand Collapse
    Staff Member
    Feb 22, 2008
    1,900
    832
    Gender:
    Male
    Occupation:
    1) It'll be a bear to hold at stop with that converter. Might want to just get a 2000 or so now so you won't have to swap it out later.
    2) T bucket brakes are easy. Most any master cylinder, forget the pressure valves and proportioning valve, throw it together and cruise. I say this IF you are just buzzing around at reasonable speeds. If you plan to go real fast or mix it up in heavy traffic, then maybe more stuff and some engineering. I've had everything from rear drums only to 4 wheel discs, and tried all the goodies without noting much difference.
  7. Golly
    Golly
    Expand Collapse
    Jun 19, 2011
    182
    30
    I'd definitely put a proportioning valve in, if you're running big & little tires. Helps stop the rear from locking up under hard braking. You may get away without it, but easier to put it in now , than have to re-hash your brake lines later.
    Hot Rod Todd likes this.
Share This Page
SSL Certificate
