Have you contacted the manufacturer of the frame/steering gear to see what they recommend? They designed the system so they should be able to recommend a safe modification to the steering gear to quicken the steering response.
They will not recommend a modification that would have the possibility of failing when at speed.
Remember it's your ass and your passenger's ass if the steering fails because you made an unsafe modification to the steering gear.
Think about it. John
Have my bucket together,took it out on the road,seems to have way too much steering,5 turns lock to lock, not very quick ,vega box,with 6 in center to center pitman arm,how can i fix it so im not turning the wheel for ever, oh 15 in wheel
thanksView attachment 11644
