I've gone back and read all the old posts about steering stabilizers. I understand that some people are not in favor of them but it also seems some people have had luck with them. So, after trying some recommended ideas - alignment, balance, out-of-round - I recently purchased a stabilizer from SO-Cal and plan to install it.
First, although I've seem a couple of ways to mount them I believe the correct way is one end to the tierod and the other to the radius rod. Second, it seems it doesn't matter which end is which as long as it is attached in those locations. Correct so far?
The So-Cal stablizer has a bend of about 30 degrees in the first one inch of the shaft (see photo). The problem I have is the limited amount of opening I have (and can add) in the track nose of my car. You might be able to see the current opening where th tierod passes through in the second photo, there is some room to expand the opening and make a new trim plate but not much before getting into the hood side panel which I'm trying to avoid.
I'm thinking about heating and taking most of the bend out of the shaft and mounting the stabilizer almost parallel to the tierod. And so my questions: Any thoughts on the effect of making this change? Is there any obvious reason for this bend and mounting angle? I could go ahead and change the bend and see what happens but thought I'd ask for opinions before messing with the stabilizer. I understand that any heating of the shaft would have to be isolated from the shock absorber.
Thanks,
Bruce
Thanks,
Bruce
