Here's the pics for post #8;
You will have to grind clearence for the inside radius on the ends of the front cross member. Be sure to make a refrence mark on the tube.
Using a tri square with two heads is the best way to ensure the tubes are stacked directly on top of each other. I use 2 of these on each section before clamping the stack down.
