TP steering joint
s19243h
i was wondering what you guys have done if anything about the total performance steering sleeve have you replaced it with a steering joint or left it as is i have herd instances were the steering shaft splits were it goes into the box
I would use a U-joint.
anyone know what size? the end of the steering shaft is round and split on both sides the steering box saft has a pin going through it that the shaft slides on with a coupler over top
