GAB said:My guess would be that that started life as a piece of aluminum bar stock that got mounted on a milling machine and the outer edges were profiled with a corner rounding bit and the grove was cut with a end mill. Upper end edges were treated to some attention with the same corner rounding bit.
I would doubt that you will find that on somebodies shelf but it should not be too hard to machine if you have the equipment or access to some.
railroad said:On my T the bare glass goes against the fiberglass of the body with a bead of silicone sealing it.
thanks,
RPM said:We make a few windsheild frames here and there. We use 7/8" round to start with and then mill away where the glass goes.
We do make a frame for the big boy bodiesHey Ron, I know this is an old post, but do you still make windshield frames or at least the channel? I'm going to need a wider and maybe taller frame for my bigboy body. Haven't mounted the posts yet, but that's going to happen soon.
Brian
