donsrods said:From what I can tell from the photos they look very much the same. However there could be some dimensional differences that I can't see. Henry was not known for spending money on lots of different parts over the years, so he probably just reused Ford spindles on the Lincoln.
I do know 39 Lincoln brakes bolt on Ford round and square back spindles, my Kid has them on his RPU.
Youngster said:ok did a little research on your lincoln breakes this morning. they do work on ford spindles as don said, but you have the lincoln spindles that will fit on the ford axle so it seems you made the best possible score on your purchase. when you pickup that front end, ask if he have the rims too. those drums have the wide 5 pattern so you will need the lincoln rims or maybe a pair of ford wide 5's.
you would do well to get a hold of bishop and Tardel's "how to build a traditional ford hot rod' mike used the lincoln brakes on his '29 hiboy. it'll tell you what's what with those brakes starting on page 58.
i might add this is a great book for those who are building a car with a traditional flavor. tons of good info and lots of pics.
Youngster said:i wouldn't be surprised if the '36 to '39 ford wheels would fit. they would also be narrower than the lincoln rims. i see in the pic of the front end, the rear end is sittin there too. is it for sale? a bucket with wide 5's all the way around would be cool too. it would be a simple matter to have a pair widened.
your other option is to find a pair of drums for a '40 to '48 lincoln. that would give you the 5 on 5.5 bolt pattern. sorry ... you won't be able to redrill for a smaller bolt pattern.
I doubt if the vw bolt pattern is the same. but you could use the 4.5 wide rims with some ford centers.
Youngster said:cool ... al you need now is a nice full dressed flatty and '39 trany!!!!!!
