This project started about 6 years ago when I bought the roadster from
John Taylor in Fresno, Calif.
While it was drivable and licensed, it had some issues and needed work.
But I saw what I wanted and lots of potential.
The car has been stripped all the way down, sand blasted, lots of welding and reworking but is finally close to being done now.
It is a cut down 1922 Dodge touring car, channeled 5 inches over the frame.
A 1929 Ford frame, zd 11 inches in the rear and narrowed 4 inches at the firewall.
It is boxed from a foot before the Z to the rear of the frame.
1949 235 Chevy hi-torque 6 cylinder, with McGurk cam and intake with 3 Stromberg single barrel carbs.
Nicson valve and side covers, Mallory duel point distributor.
!936 Chevy 3 speed transmission.
1946 Ford running gear, with a 5 drop Dago axle.
The rear suspension and radius rod mounts were reworked during the quick change install.
The quick change is a modified stock banjo housing, done in the Midwest during the late 50s, early 60s.
The housing is rotated 180 degrees, and spur gear box and drive shaft - quill shaft entrance are welded on.
It was never finished machined or installed.
Steve at Lime Works in Whittier, Calif., did the assembly and the brain storming to put it all together.
I couldnt be happier with the finished rear end and I still need to paint the axle bells.
Basic paint and upholstery will come as soon as I have the time...
That is the basic rundown of the car for now, it should be back on the road again soon.
Attached are some before and after photos plus some build photos.22
