TRoadster
I'm getting geared up to swap out my old ford rear radius rods for a stronger 3 link set up.  I have a question about mounting the lower control arms.  My 9" rearend has a wrap around mount already welded in place for the ford rods.  Should I make a mount for the lower control arm that I can bolt onto the preexisting mount with two 1/2" bolts or should I go ahead and weld on new mounts on either side.  Either way, I'm not going to remove the wrap around mounts.  It would be easier to weld together a new mount out of 3/4" and 1/4" steel and bolt it in place.  What do y'all think?
