The things one doesn't know. I found this on Team Camaro site re SBC filters:
"You do not have a problem. Several filter companies (AC included) have downsized the SBC filter yet the parts catalogs still specify one filter for all years. I have personally opened two SAME BRAND filter boxes of slightly different size with the same part number and the filters inside each had different diameter seal area. I found this after pumping a half quart of oil past the oil filterseal and onto my garage floor while using a drill and priming tool on my engine that had sat for seven years.
The Purolator L20049 (and some other brands) is still the correct size. Here is a picture of the Purolator L20049 and an AC DelcoPF1218specified for a '65-'92 small block sitting seal to seal. You can probably compare a couple different brands in your local store and find the same thing".
"The AC 454 filter is 3 5/8 " in diameter & the rubber seal is 3 5/16" in diameter.
The Purolator L20049 filter is 3 3/4" in diameter and the rubber seal 3 1/2" in diameter".
Apparently some filters were downsized and won't seal! Check the diameter of your filters and let us know what you find.
