So I'm out picking up parts for a T bucket build, and I ended up with a complete 48 Ford front end mainly for the spindles and brakes. Upon further eyeballing the spring and axle seem to be in nice shape. I realize the perch hole locations are wider than "normal" causing interference issues .So I'm wondering if anyone has succesfully used this set up? Tire size, or rim offset perhaps or just wishbone to fix.
Also, the rear to the 48 is available but I'm unfamilar with these. Would it work well in a small block based bucket?
Thanks!!
Thanks!!
