Indycars
Now that I have my SS tubing I need to know how long to cut each tube. So I setup the car loaded on the springs with a 5° rake and 5° caster angle. Then I measured the distance, center-to-center to each mounting hole. Now I measure each component and what it added to the length of the radius rod or what will be subtracted from the tubing actual length.
When considering how much to leave on the rod end threads for adjustment I wondered how much it took to change the caster by 3°-4°. So that’s when I decided to measure the change over a significant distance to get an average. Below is what I found.
The average change per turn of a single lower rod end was 0.6°. Now this was adjusting just one rod end, so adjusting the radius rod with both RH and LH threads would theoretically change the caster by 1.2° for each full turn of the radius rod.
[(8.7-3.2) / 9)]*2 = 1.2°
Wixey WR365 Digital Angle Gauge
www.amazon.com/gp/product/B0054RJ7VC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
QA-1 1/2" Rod Ends, LH & RH
https://www.summitracing.com/parts/qa1-xml8
https://www.summitracing.com/parts/qa1-xmr8
