I looked at some of that today here in Nashville at advanced plastics.Polyvinyl Alcohol. To keep parts from sticking together.
Sprayed in light coats, (3 to 10 coats) it builds up a barrier between the plug or mold and the finished part.
You can spray it on foam, plaster, wood, etc.
Peels off easily when done and looks like a layer of green Saran wrap.
This new version is low VOC and has even heavier solids.
What weight chopped strand are you using or recommend? I'm thinking about making my own fenders if needed by the DMV.
Thanks for the info. The work you do is amazing. Where do you get most of your supplies? Does the gel coat come a bottle? Do you buy the fiberglass in big roles? This is my first time building a car. So everything is new to me. All you guys have been very helpful. Thanks
Holy cow I'm tired.
Each one of these stacks is 5 layers of 2oz. mat. Should end up around 1/4" thick.
It took 3 weekends to prep all 230 pieces.
And 2 1/2 long days to lay it all up. I'll pop them out of the molds next weekend.
All that glass work looks great. Going to be one of a kind for sure. Are you keeping the molds for future use?
Lee
