Sounds like your floats may be too high. I would check them with the sight plugs. If you have an electric fuel pump you can get real close with the engine off. I did not see what power valve you installed. By the number, your cam seems mild, I would think your idle vacuum would be a little higher, although 10 gauges will you give you 10 different readings. If it has not been back firing, look down into the carb while idling. You should not see any fuel dripping from the boosters or pump nozzles.
