I don't know that you would consider mine to be simple, but it is wired from scratch.Has anybody started from scratch and used something like this?
I was thinking about this while staring out the windshield after work last night.Some vehicles were equipped with ground straps to the radiator. It is true that electrolysis can occur if not properly grounded. When I worked at the radiator shop in high school I seen many radiators that were rotted out due to this issue. I’ve seen the impellers on water pumps completely gone from it too. Most radiators are rubber mounted, t buckets excepted, so the path to ground is the coolant if no other path is provided.
When do you blast off for Mars?I did my wiring from scratch. My doctor says I can taper off my meds any day now.
