Found this from way back when. Maybe it will help.
Maybe their website?
Self Canceling Turn Signal Module™
$74.95
SKU:
01501
Rating:
Quantity:
Product Description
The Self Canceling Turn Signal Module™ is an electronic flashing relay that is meant to completely replace your existing mechanical flashing relay(s), or be a stand alone flashing relay to vehicles that do not have turn signals. It works with both LEDs or incandescent lights up to 10 amps per output(20 Amps Max). This module does not require any load equalizers because it is a self-timed electronic relay.
Please Note:The Self Canceling Turn Signal Module™ requires momentary push buttons to operate (not included). Latching-type switches, or push to cancel type switches, will not work properly because these types of switches send constant power to your turn signals when on and will defeat the main purpose of the self canceling feature.
Features
• No flasher relay needed
• 3 user selected flash periods
• Automatically self-cancels
• Works with LEDs and incandescent
• Hazard flasher feature built in
• Waterproof and heat resistant
Turn Signal ModesMode 1 : Press turn signal button for 1 second, turn signal light will flash for 7 seconds, then self cancel. This mode is usually used when changing lanes.
Mode 2 : Press turn signal button for 2 seconds, turn signal light will flash for 20 seconds, then self cancel. This mode is usually used when slowing down to go around a corner.
Mode 3 : Press turn signal button for 4 seconds, turn signal light will flash for 75 seconds, then self cancel. This mode is usually used when stopping at a signal light and turn will be made after stopping.
Note: All three modes above can be cancelled by pressing the same turn signal button a second time.
Mode 4 : Hazard Mode - is available all the time and will flash until cancelled. To engage, depress both the left and right turn signal buttons for 1 second. To cancel, depress both buttons again for one second.
Specifications
Part Number: 01501
Weight: Less than 1lb
Amp Limit: 10 Amp Per Output (20 Amps Max)
System Requirement: 12VDC(-)
Attachment Method: Included Double Sided Adhesive Pad
Height (in): 5/8"
Length (in): 2 1/4"
Width (in): 1 5/8"
Wire Length: 5"-6"
Material: Anodized Aluminum Case with Heat and Water Resistant Potting
Wire: 16AWG - 20AWG
Package Contents: (1) Self Canceling Turn Signal Module™, (1) Adhesive Mounting Pad
Color / Finish: Black Anodized
Hardware Included: No
Connectors Included: No
Tools Required: Wire Cutters/Splices
Waterproof: No
Water Resistant: Yes
Heat and Vibration Resistant: Yes
Companion Product(s): n/a
Having a difficult time deciding which module best suits your needs? Take a look below to see the differences between them!
Warranty Information
Signal Dynamics Corporation warranties this product at time of purchase to be free from defects in material and workmanship to the original purchaser. Signal Dynamics Corporation's obligation under the warranty is limited to repairing or exchanging the unit if the unit is returned with the postage prepaid to Signal Dynamics Corp. within 1 year from the date of purchase. The warranty is void if the unit has been incorrectly installed, damaged, or tampered with. This warranty specifically limits Signal Dynamics Corporation's liability to unit replacement only and specifically excludes any consequential damage arising from use proper or improper or failure to properly function. A copy of your purchase receipt or other proof of purchase is required when applying for warranty consideration.
See full Warranty and Return Policy!
Find Similar Products by Category
Customers Who Viewed This Product Also Viewed
