axle question for Mickey Lauria
butch27
Micky: On the front axles you sold ( I bought one). What is the Caster and Kingpin inclination built into it and does the little set screw to hold the kingpins in place go toward the front? Thanks
The king pin inclination will depend on which spindles the axle is for. The caster for the most part will be set when you install the axle in the chassis
