Keeper
Okay I have a plan for mounting my battery. I am using an Oddessy battery, that will fit nicely between my frame supports.
The plan is to mount it between the two parallel cross members on its side.
The questions I have are:
1. Should I be worried about the battery terminals getting wet?
2. How much protection is needed? The battery is small enough that you will not see it from the side as the frame will cover it.
I was thinking of making a tray out of some 10/12 gauge steel. With a frame of 1x1 angle. The design will not allow the battery to slide toward the frame and shorting things out. Anything else I should worry about?
