I dont watch a lot of TV but the other half does. Loads of American programs over here, she is into Grimm at the moment.Gerry, do you brits watch American TV as much as we colonists watch your TV? Do you know what Acorn is?
Acorn is an internet site that carries British shows, many of which we don't get here on PBS or BBC. Right now we're watching The Tunnel. And we are working our way thru 20 years of Midsomer Murders. You guys do great mystery. And great comedy; I have watched all the IT Crowd shows over and over.I dont watch a lot of TV but the other half does. Loads of American programs over here, she is into Grimm at the moment.
Me - Big Bang, British Super Bikes, nature programs and that about it. Acorn???![]()
Good to see that you are still hanging out with the rest of us thugs here!How's that Flex-a-fan unit working? Easy to set temp? Does it hold the coolant temp steady?
Well you picked the right branch to climb out on, it's for crossing a water hazard. I suspect it's intended for 4-wheel trucks, mud racers, etc.What is the "water crossing" switch? I'm gonna go out on a branch and guess it's to turn off the fans while fording a stream or other water hazard.
The water pumps usually have a threaded hole for the heater return, but since T-buckets generally don't have a heater this hole gets plugged. I put the fan sensor in that hole so it reacts to the temp. of the water coming out of the radiator, just as you said. That has always worked well for me.Years ago I had a Mustang with a electric fan, I put the bulb style temp sending unit in the lower hose because I wanted to know (or I should say the FAN SHOULD KNOW ) the temp coming out of the radiator, not the temp coming from the motor(where most sending units are located). If the motor is running hot it will show in the temp. of the coolant coming from the rad. first no? Opinions? Well the car and engine ran great with this set up, no over heating or hot starts.
Ah, my unit will be so smart it will work with one sensor located anywhere in the coolant system. And it might even sense timing and tell the owner if it is not optimum. I'm thinking of calling it the OCD Mark I, because only those with OCD would want a fan controller that costs more than a new motor. I'm not a well person...aybe in your design PotvinGuy, you can run two (2) senders, one on the motor inlet side(low temp ~ 160*), the slow speed fan switch and have a sender on the outlet side (high temp~190*)kick in for the high speed fan switch.
