I'm still trying to figure out this blower. I finally got the correct instructions from Barry Grant after a good tongue lashing from me about sending the regular manual with the blower carbs. BG is useless when it comes to support. These blower carbs have a 1/16 NPT port under the primary bowl that is for sending a vacuum signal to the power valves. So I had to find two 1/16" NPT male to hose barb fittings. Nobody in town had them and I tried everybody including Stuart Hose in Lewisville, TX. I finally found two -3 AN male to 1/16" NPT male fittings and one of the hose barb fittings at a speed shop over in Fort Worth, so after some trial and error I got the vacuum line hooked up to the vacuum assisted power valves. I also re-curved the distributor so it is now 18 degrees all in at 2500, which is what MSD, Dyers and BDS recommended. I spent most of the afternoon trying to get it to idle. I've re-read both of my supercharger books and the Demon tuning books to make sure I was on the right track. I can get it to idle at around 1000 RPM with no lope, but as soon as I try to get it down below 1000 RPM it starts to surge. I've got the idle mixture screws on both sides of the carbs screwed out about 1 full turn. The timing is pretty close to 16 degrees. It seems to like having the vacuum advance hook up, so I have it connected for now. I think its about 2 to 4 degrees more advance. I'm not sure what to do now. I've got almost 20 Hg of vacuum when it idles at 1000 RPM. I noticed that my AHC coated zoomies were turning dark near the flange while I was trying to find the sweet spot. The temp gauge never went past 180 though. Im thinking about moving it from the back of the manifold to the front near the thermostat.
No matter what I try I cant get it to idle down without the blower lopesurge.
Any Ideas?
Any Ideas?
