You'll notice that when you go to do a burnout with a blower atop your motor, that, you don't push as heavily on that Go pedal. Thats a big grin maker right there.
Blower motors start making tons pf horses and torque earlier, if tuned right. One of the main things for the Blower motors is your timing.
This, these days is a direct influece of the crappy gas we have now. You cannot run a blower motor lean. if you do, you'll torch a piston or a valve.
Backfires, aviod them at all costs if at all possible. That means have your timing really close to start with. Your compressing alot of air and fuel into a small space under that blower. Also between the rotors and the carb bases. There is a explosive territory there....so be careful.
Compression and ignition are also super critical. A stock ign. system isn't up to snuff here. If you look at the motors at the drags, the Altereds and the TF's, among others run dual distributors and and dual plugs....
This is because they're blowing the flame out inside the cylinders.
Though you might have a low static compression ratio, with high boost pressures with alot of overdrive, you can blow that flame out in a street motor at high RPM's, with fairly stock heads. So when that dredful miss occurs....often, a better ignition is often the answer....
I'm talking about 6500RPM, which the nonblowns don't consider Hi-RPMs.
Last but not least....any serious blower motor....you have to change your spark plugs. For every 75 to 100 horses, you have to go to a colder plug.
And That E85 in a blower motor....just let me say....it can be problematic, at best... It just doen't have the octane. And sometimes it won't have spark rattle that warns you. Alcohol can absorb water. Water will fight detonation somewhat.
That slight cooling effect, along with not enough octane to do the job, caused a person, not long ago to have a massive meltdown while showing off in a street car.
Wasn't my setup, but i was the one that diagnosed the rubble afterwards. Nice $6500 street motor down the drain. He opened it up with crappy fuel in it....
