Ya'll need to take heed to what Mikes saying....Really and truely sometimes its hard to get everything round, straight and true with a light cut of only .008 and .002 honing....Its gotta be done on a good machine.
They'll probably want to do a light cut and finish things out with a good machine hone. Don't even play with the thought of using a bottle hone for this....it won't work. Use a bottle hone on a out of round tapered hole, and you'll just make it more so....
And Trying to prop up your compression ratio with the alum. heads and then comphensating with Cam, etc, etc, your in for heartache.
As Mike Said, save your money by doing it right the first time, cause the 2nd time around your just throwing dollars to the wind....
I might be outta place here to say this, But that last motor, oino, was a fraking fiasco. Build yourself a good, cheap motor. By CHEAP, I'm talking no alum. heads, no racing cam, no special intake and supernifty carb, just a good basic motor that will run when you hit the key and run on this crap fuel we now have.
Just a good old fashioned rebuild with quality parts, a mild rv cam, good basic small runner heads, a alum. dualplane intake like a Edelbrock C4B with a 450cfm or a 500 cfm carb with small primary headers.
It'll start good, run good, get good mileage, will stick with you for years and never let you down. Trying to use alum heads, then adjusting the recipe with the cam and all that....I don't think you can plan it out correctly.
I myself and others here do this shit for a living, and we don't 1/2 ass it, because if you do, it will come back around and bit you in the ass. I can tell you this from experience.
Keep it simple, keep it straight forward. Want .01 over, do it. You can true up your heads and use your gaskets to get 9 to 1, no ploblem.
I thought the name of this one was a low buck inexpensive motor for your T....am I wrong?
Wanna throw money at it all day, go build yourself a nice 900+ cu.in. Pro Comp Mountain motor....it'll be a nice Trailer Queen.
