bentbaggerlen
Ok, so I'm putting my bucket back together after painting the frame. I find I need to mount the body about 3/4" higher, other wise it sits on top off the transmisson. I was thinking of using nylon or rubber as a spacer, or maybe even hockey pucks would work. So far I'm leaning tords the hocky pucks. Any other ideas?
I'm not sure why it hits the body
Its a Spirit body, on a Spirit chassis (From the kick up forward) with a 302/C4 drivetrain. When I installed the engine and transmission I found that the tranny crossmember was to far forward, or the engine mount was too far back. But I cut out the tranny crossmember and moved it back about 1 3/4" so the mount would line up with the tranny. If I had moved the motor mounts forward, my water pump shaft would have run into the electric fan. As it is I have about 1" between them. That and I already have my drive shaft made, so everything is going to stay put. It would get really expencive to change it now.
