Studebucket
I know with the column, gas, brake and clutch it will be tight. I am thinking of using a T-5 behind a Stude 289. That will probably not be a problem. However, if I use the original 3 speed, I will use the column shift(3 on the tree). Does anyone have a diagram for an old style ansen swing set up. I could probably make one and new linkage if I have to. Anyone do this or have clearence issues running a stick? Thanks.
