thebearded1
I am going to be redoing the brake lines in my hot rod this fall/winter since i'm having some issues with leaks and components in areas tough to get to. Currently the system is: 1940 Ford hydraulic drum brakes up front, 1995 jeep rear drum brakes and 3/16" lines going to the front and the rear. I'm thinking about going to a 1/4" line for the front brakes since that is what originally used for those brakes but keep the rears 3/16". Has anyone done a setup like this before? I assume there shouldn't be an issue using different line sizes on a brake system.
