I am having a problem with the brake pedal not returning all the way, it stops about a 1/4" to 3/8" from the top, but it only does it when the engine is running (have power brakes). It returns fine when the engine isn't running, so i am suspect of the power booster. Do power brakes need a return spring on the brake pedal arm, I thought only manual brakes needed a return spring, but I have been wrong before! With the brake pedal arm not returning all the way, the brake lights stay on and sometimes I get a high pitch noise coming from the passenger side break calipers, it stops the second I pull up on the brake pedal. I should also mention I only get about 12-14 hg of vacuum and it is a dual chamber 7" power booster connected to a 1 1/8 corvette master cylinder.
Any ideas?
Thanks
			Any ideas?
Thanks
