Hey ChopperTom! Have you looked at the new paint that I have been seeing pop up on more and more custom bikes that looks like chrome? It may take some experimenting but I have seen some that look very close to chrome, first ones look more like Jet Hot and some of those type coatings, but lately look real close at first glance. That way you can use your current fiberglass shell and if you don't like the present insert, there are tons of different corrugated metals out there to choose from in all types of finishes. One other idea that came to mind is have you considered the polished stainless trim that sticks on that you see on cars and trucks that they use it as a guard on the lower part of the body and rockers? It's fairly light and flexible, and you could cut it into panels for the front of the shell and it would be easy to cut one piece to do around the outside. Would have to be careful cutting and shaping it so it doesn't look bad, but if done right it would look great, and have your body color for contrast, similar to some of the polished firewalls you see on buckets, same idea. Hope this helps and is food for thought. Good luck and post pics if you give this a shot! Eddie
