Back in SuperStock when we'd run QJets, we had to epoxy the welch plugs on the bottom of the carbs or sometimes they'd fill the crankcase or partially fill the intake....
Shhhh! Don't give away all of the secrets!
![Laugh :laugh: :laugh:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I hate to think of how many hundreds of Q-Jets I've epoxied up.
I have an electric fuel pump. There is gas lying inside the carb just below where the gas line attaches.
OK, we're getting into some gray area with your definitions of where you are seeing gasoline. When you say 'inside the carb', do you mean you are seeing gasoline puddling on top of the front throttle blades? Or have you actually had the top of the carburetor off?
If you are seeing gas on the throttle blades, then you have one of three things happening. Either A) your float level is set too high, B) something is stuck in the needle and seat assembly, preventing it from closing, or C) you fuel pump pressure is too high and needs to be regulated down.
Try this simple test. First, open every window and door on your garage, and set up a fan or two, to get the gasoline vapors out of the garage. That, or push the car out into open air. DO NOT WORK ON THE CAR WITH RAW GASOLINE VAPORS IN THE AIR! And don't start the car to get it out of the garage, because it sounds like you are filling the crankcase with gasoline.
Once you have the air cleared of gasoline vapors, remove the air cleaner from the carburetor. As you are looking down the throttle bores, have someone turn on your fuel pump. Do NOT start the engine, just turn on the pump.
Do you see gasoline pouring into the throttle bores? I suspect you will, which means you have one of the three problems listed above.
Once you get the problem fixed, be sure to change the oil and filter, because you do not want that gasoline-thinned oil in the crankcase.
If, on the other hand, you have removed the top of the carb and you are seeing gasoline inside the float bowl area, that is entirely normal, and is naught to worry about.
