Screaming Metal
Oh yeah, I forgot about those. How long after we left did the cops show up?
I Like IT! My Kinda Folks!!!!!!
More to add to the list.
Do not use rtv on the rubber end seals of the oil pan.
I always put a dab at the corners where the rubber meets the fiber gasket.
I recommend checking coil bind clearance on any cam change. And trying to measure between coils can get you into trouble, as most springs do not compress in a linear fashion, from one end to the other. Put a retainer on a valve, install a pair of locks and pull the retainer up against the locks. Measure from the spring pocket to the bottom of the retainer, where the outer-most coil will locate. That number is your installed height. Now, take one of your springs and run it down solid in a vise. Measure the spring and you now have coil bind height. Now, multiple lobe lift by rocker ratio to get valve lift.Even if your just stepping up to a .535 to .55 lift cam, check for coilbind, and for guide to retainer clearence. .535 to .550 gets really close on some motors, so its best to check. Be sure .04 to .06 between coils, if its closer than .035, have your spring pockets redone.
X2I always liked to spin the block upside-down on the stand, so I could get my fat fingers into the cam tunnel. That way I could support the back end of the cam and help guide it in that way.
