swatman260
I have a barely used FAST Ez EFI kit for sale. This kit includes everything you would need to swap your carburated engine over to modern, self-learning, fuel injection. The throttle body will fit any 4150 style intake and still retains the classic look of a carburated engine, with the fuel economy and performance of fuel injection. This kit was briefly installed on my vehicle and was only driven about 600 miles.
New, this kit sells for over $2500. If you have read my previous threads, you may have noticed that I had some problems with this setup.. which were all related to my installation. Unfortunately, the way my wiring was run really didn't allow me to install this kit the way it needed to be installed, and as a result, I had electrical interference issues. To verify this, when I removed the EFI from my bucket, I sent the entire setup back to Comp Cams for testing. All parts have been tested by the factory and have been confirmed to be in perfect working condition. It is all As-New from the factory.
Included is the throttle body, handheld control module, wide-band O2, in tank fuel pump, fuel pressure regulator, and all wiring harnesses. Everything you would need except a few plumbing fittings. All original manuals will be included.
This is a great chance to get the top rated fuel injection system for a huge discount. Please call if you have any questions @ 850-528-6150.
If you contact me directly, I will be glad to send photos to verify the condition of the kit.
