I have an 88 T-bird 8.8 I'm planning on using for my build...and checked out the Crown Vic units. The reason I went with the T-bird unit is that the CV unit's Watts link is notoriously is notoriously weak, I did not like the looks of the control arms and bracketry, the control arms were set to wide for my liking, And I wanted a numerically higher axle ratio than available with the CV. Width wise, the CV is in the low 60s face to face...wider than most like...but the width works well for my purposes because my body will be backed up between the tires , and I want all the body/tire clearance I can get.
The T-bird 8.8s are the same width, but are set up for a triangulated 4-link ,that to me looks cleaner, and uses all the Mustang high performance suspension components that are widely available. It comes with either 3.73 or 4.11 ratios.
I am traveling right now, and do not have access to the exact width and CV ratios on the 8.8s, but if no one has the figures handy by early next week, I'll see what I can find.
