donsrods
I thought I would give an update on a problem we were having with my Son's T bucket, it had violent death wobble when you accelerated and the only way to stop it was to stomp on the brakes. Part of the problem was we rushed building the car, we did it in 88 days, start to finish because we were shooting to have it done for Turkey Run last Thanksgiving weekend. That was a complete build up, including building a new frame from scratch.
Finally we decided to just go back to square one and redo all the alignments, rebalance the wheels, and get the heavy GM brakes off of the front end. We found a lot of things wrong, like the wheelbase was 9/16 off side to side, the toe in was 3/16, the caster was too much at 11 degrees, the tires were out of balance and one brand new rim was bent right out of the box. I also adjusted the Flaming River steering box to take up some slop, and realigned his pinion angle. We also cranked down his friction shocks a lot tighter.
He hasn't driven the car since November mainly because of the handling issues, but also because his brand new TCI streetfighter transmission went out. TCI sent us a new one and new torque converter, and we finally got that installed a few weeks ago.
To make a long story shorter, he has been using the car a lot in the last few weeks and it goes right down the road now.
Just last night we took our two cars to a cruise and he can now get on it hard and it never had one problem. He can one hand it going down the road, and it doesn't wander like it had been doing.
I think the biggest thing that helped was getting the heavy GM brakes off of the front end and putting much lighter Wilwood brakes on it. We also replaced the spindles with brand new ones, and found one of the old spindles was turned 5 thousandths too far, allowing the outer wheel bearing to be sloppy. I thought I would tell anyone who is having a similar problem that it is curable, you just have to keep playing with the car and make sure everything is set up correctly.
