one finger john
In this months Popular Hot Rodding (October), there is a comparison article that involves attaching a TPS sensor to a carburetor and in one test use the carb alone as a carburetor while in a following test use the carb as a throttle body for fuel injection. Everything else was the same. Engine, cams, headers, intake manifold, all were the same. Injectors were positioned in the manifold so they were left in place while the carb tests were run. After the tests the question was asked weather using both F.I. and carburetor at the same time would provide a performance advantage. The only answer was a cryptic "Yes". Any comments on the possibilities and probabilities on such a combination ?
John
John
